top-James
Aqua Tower is a home water generation system that uses advanced technology to extract moisture from the air and produce clean drinking water. It is a revolutionary mechanism that is highly relevant in a world constantly threatened by water scarcity and disasters. The device offers hope to millions of families struggling to live through droughts and frequent water shortages.
Click To Access The Aqua Tower Official Website
Aqua Tower introduces an innovative solution to tackle water emergencies without worrying about contamination or monthly bills. The most attractive feature of Aqua Tower is that it produces water from humidity content in the air. In this Aqua Tower review, we will examine how the system provides access to an endless supply of fresh water without relying on municipal water systems.
Aqua Tower – Quick Overview
Product Name: Aqua Tower
Type: Atmospheric Water Generator
Creator: Richard Wilson
Technology: Atmospheric water generation through condensation
Key Components:
Air filtration unit
Condensation coils
Multi-stage filtration system
Water storage tank
Materials: High-grade, cost-efficient, easily accessible materials
Water Filtration: Multi-stage, including UV sterilization
Installation: Easy DIY assembly, requires no technical expertise, 1-hour setup
Benefits:
Continuous water supply
No monthly water bills
Emergency water supply
High-quality water in contaminated areas
Price: $39.69
Refund Policy: 60-day money-back guarantee
Where to Buy: Official Website
What Is Aqua Tower?
Aqua Tower is a DIY atmospheric water generator that facilitates sustainable water supply regardless of environmental conditions. It was developed to address global water scarcity issues and uses atmospheric water generation technology. The off-grid system features a portable and highly functional design that is time-tested to ensure durability.
Unlike conventional water filtration systems, Aqua Tower doesn’t rely on local water sources. Rather it utilizes atmospheric moisture which makes it functional in various geographical locations despite climatic conditions.
Working Of Aqua Tower Explained
The Aqua Tower water generator is a fascinating example of how technological advancements can help resolve the greatest challenges faced by the world. The generator depends on natural processes to produce a sustainable water source that can deliver around 60 gallons of water a day.
Aqua Tower is made using highly efficient and durable materials that are easily accessible. The device is user-friendly and does not require much technical expertise to set up. The system works based on a simple condensation principle. The process is similar to the principles applied in air conditioners to cool a space.
It extracts humid air and cools it below the dew point to create condensation which is transformed into drinkable water. The extracted water is passed through multi-stage water purification filters to eliminate dirt and contaminants. Aqua Tower is easy to set up and energy efficient, facilitating continuous water supply without high utility costs.
Visit The Official Website To Learn More About The Benefits Of Aqua Tower
About The Creator Of Aqua Tower
Aqua Tower is developed by Richard Wilson, a third-generation farmer living in California’s Imperial Valley, on the outskirts of Salton City. Living in a place known for its scorching temperature and frequent water scarcity, Richard has dealt with droughts all his life. A devastating drought that took place in 2015 turned out to be the rationale behind the creation of Aqua Tower.
Aqua Tower Review
The water independence device was developed to save his family and others from the life-threatening situation they were trapped in. With pro-grade, yet cost-efficient materials, Richard set out to build an advanced and sustainable water generator that uses a modest amount of power to operate.
What Is Inside The Aqua Tower?
Aqua Tower atmospheric water harvester is designed based on well-established scientific principles related to condensation and dew point. It combines high-grade technology with the hygroscopic nature of water and the thermodynamic process of condensation to produce drinkable water. Here are the core components of the water generator:
Air Filtration unit
Aqua Tower features a powerful air filtration unit that removes airborne pollutants and microbes. The filtered air is then pushed towards the condensation coil. This is especially beneficial in areas where the quality of air is highly compromised.
Condensation coils for water extraction
The condensing system uses a compressor to circulate the filtered air and an evaporator to cool the air. Once the air reaches the dew point, water vapor is condensed into liquid which passes to the purification filters.
Multi-stage water purification filters
The multi-stage water purification filters in the Aqua Tower system remove impurities and ensure that the purified water meets drinking standards. The filtered water is collected in a large storage tank.
Water storage tank
The water collected in the storage tank is pure and free of dust and disease-causing particles. It is of drinkable quality and can be consumed without worrying about hygiene. The generator is said to produce around 60 gallons of water a day, which may differ according to the humidity, temperature, and cooling capacity of the device.
Click To Get Access To The Official Website Of Aqua Tower
Specifications Of Aqua Tower
Besides employing technology that makes water from thin air, Aqua Tower is unique in terms of its design, installation, and features. Its distinguished and customer-friendly approach is what made it one of the highly desired water generators in existence. Here are the major specifications of Aqua Tower:
Dimensions: Height- 4 ft, Width-2 ft
Weight: 150 pounds
Power consumption: 800 watts
Water storage capacity: 20 litres
Water filtration system: Multiple stages including UV sterilization
How To Use Aqua Tower For Optimum Results?
Aqua Tower humidity to water converter displays a user-friendly design and is easy to assemble. It accompanies a detailed user guide that contains complete directions on setting up and using the device.
The manual is easy to understand and does not require any technical expertise to follow. Materials required for construction are easily accessible and cost-effective. By following the instructions correctly, Aqua Tower can be operated in less than an hour.
Aqua Tower should be set up in places with good airflow and minimum pollutants. In order to function efficiently, the generator should be connected to a power outlet normally used at home. Here are the initial steps involved in operating the gadget:
Filling the mineral cartridge
Set the desired temperature
Adjust humidity levels for optimum water generation
Benefits Of The Aqua Tower System
Aqua Tower is a long-term investment that gives free access to clean water and protects individuals from the rising threats of water scarcity. The multitude of benefits that accompany its installation makes it worthy on different levels. Let’s discuss some key advantages of setting up the Aqua Tower system at home:
Key Components:
Air filtration unit
Condensation coils
Water storage tank
Benefits:
Price: $39.69
What Is Aqua Tower?
Aqua Tower Review
Air Filtration unit
Water storage tank
Weight: 150 pounds
